How to Rip DVD to iPod on Mac?
03/24/2022
Do you have an iPod? If yes, then which model of your iPod is? As we know, during the evolution history of iPod, there have been several models to date. They are iPod classic, iPod Shuffle, iPod Nano, iPod Touch. If yours is iPod Touch, then you’ve got an excellent video player on the go. Compared to iPhone, the only missing feature of iPod Touch is the ability to make voice calls. This is, on the other hand, a good reason why iPod Touch has a longer battery life for watching videos.
How to make videos to watch on your iPod? You should ask for help from a Mac DVD ripper software, which enables you to convert DVD movies on your Mac into your iPod ready videos. Now, this tip below will teach you how to do that with the helping hand of DVDFab DVD Ripper for Mac.
Read on if you are dying to find such a program:
Convert DVDs on Mac for iPod: Step 1-> Download and install the latest DVDFab 9 for Mac onto your Mac;
Convert DVDs on Mac for iPod: Step 2-> Launch DVDFab 9 for Mac, choose Ripper option from Option Bar at the Main Interface, then add your target DVD movie per the instructions;
Convert DVDs on Mac for iPod: Step 3-> Choose the correct audio track and subtitle stream you need to retain at the corresponding sections, and then set the output path at the “Save to” section to a place you can easily find on your HDD;
Convert DVDs on Mac for iPod: Step 4-> Click the Profile Switcher to find corresponding profiles for iPod from the built-in Profile Library and press "OK" button, then just hit “Start” button at the Main Interface to go converting.
After the task is over, just transfer the converted videos onto your iPod and that’s it.
Note:There are several profiles for different generations and models of iPod, please select the one matches yours.
Software you need: the latest build of DVDFab 9 for Mac
Product you need order: DVD Ripper for Mac
For further info, just visit www.dvdfab.cn/dvd-ripper-for-mac.htm
